2oldman
Dec 13, 2015Explorer II
I think the OP explained quite well what he did.
In a series connection, voltage is additive while amperage is constant and limited by the lowest amperage device in the circuit. So, you may as well not even have the 2 batteries in parallel since they are acting as 'one' 6v battery in series with the 3rd.
I think you should remove the other paralleled battery.
enblethen wrote:x2 - while charging all 3.
You are cooking the series battery while trying to charge the two in parallel.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
