Boon_Docker
Dec 13, 2015Explorer III
TimLoon wrote:
Well, at least it was an interesting discussion. Last question: With 3 battery spaces, am I better off with the 2-6V or 3 - 12 volt? If 3-12V, what batteries would be best knowing I have the space to accommodate the 6V size batteries? Will probably be adding another solar panel in the spring.
For a comparison:
Two GC2 (6v) will give you 225ah
Two Trojan T-1275 (12v) will give you 300ah
So three T-1275 (12v) will give you 450ah
The T1275 is the same width as the GC2, but almost 3 inches longer.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
