CA_Traveler
Dec 14, 2015Explorer III
TimLoon wrote:You should be OK with 2 6s but you can get more AHs with 3 12s depending upon space and battery size.
Well, at least it was an interesting discussion. Last question: With 3 battery spaces, am I better off with the 2-6V or 3 - 12 volt?
But parallel batteries should be wired in a balanced manner for maximum performance and battery life. For 3 in parallel this means a completely different wiring setup setup for the batteries. Although unbalanced wiring will work this is just a FYI. Lot's of information available on balanced battery wiring.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
