Almot
Dec 14, 2015Explorer III
CA Traveler wrote:
you can get more AHs with 3 12s depending upon space and battery size.
But parallel batteries should be wired in a balanced manner for maximum performance and battery life. For 3 in parallel this means a completely different wiring setup setup for the batteries.
Yes. See Diagram #2 Here. #1 is Unbalanced wiring. #2 is "almost balanced" - much better than #1 and is not complicated, you can use the same interconnect cables.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
