Darklock's avatar
Darklock
Will a 100 watt solar panel be enough
Just looking for a way to keep the battery (single 12 volt) charged while going down the road and run the fridge and a few led lights when boondocking. I would like to get by with just a single 100 watt panel on the roof. Would this work under average conditions?
  • The only way you are going to know is by doing an assessment of your actual use. A 100 watt panel will produce up to 30 amp hours per day under ideal conditions, less if you don't follow the sun, and on cloudy days. Many owners of small fiberglass trailers have no problem using a single 100 watt portable panel, others require far more.
    If you winter camp, and run the furnace, it will be difficult to keep the battery up.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
