dougrainer
Jul 26, 2013Nomad
Ranger Smith wrote:2edgesword wrote:
A compressor will run without freon but won't cool.
Compressor will not run without freon. The low pressure switch shuts it off.
The OP is talking about Roof Top AC units, NOT Auto Dash Air units. There is NO switch or system on RV Roof top units that prevents the Compressor from running when their is NO Freon. Depending on the type leak (Large or small) the other problem on Roof Top AC units is HOW MUCH oil leaked out when it lost its charge. If the oil loss is significant (you will see the oil in the pan), then it is not a good idea to fix the leak and recharge. Better to replace the roof top unit. If the compressor is HOT to the touch then the Freon is gone. Replace the roof top upper unit. Doug
