rjsurfer's avatar
rjsurfer
Will laser heat sensor find inadequate battery cables?
Just curious if I can use one of those heat gun devices to detect inadequately sized battery cables and connection points in my solar system?
I'm only getting 15 minutes of run time on my 1200watt microwave on high before the low voltage sensor kicks in.
Running 4 GC batteries (440 amps), 2000 watt full sine wave inverter with 700watts solar.
My thought is to run the microwave on high and check each battery cable in the system to see which ones might be undersized by the amount of heat they give off.
Is this a valid test?
Ron W.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Jun 17, 2022
