pnichols
Nov 15, 2016Explorer II
Beverley&Ken wrote:
You will be fine. I've got a 2006 Winnie Outlook 29b, Same converter, that's been plugged in for about the last 6 years, except when being driven.
Batteries are good, just check the water levels periodically. I've also got a trik-l-start wired into the chassis battery (and plugged into coach 120v system).
No problems at all.
Ken
X2!!
That's about our situation with our 2005 Itasca Spirit using only it's stock converter for over 10 years. However, I use AGM coach batteries in it that are spec'd to be floated at 13.5 - 13.8 volts - not the usual float spec of around 13.2 volts. My coach batteries are on the converter almost full time except when they're getting 14.XX volts from the engine alternator while traveling.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
