valhalla360
Nov 18, 2019Navigator
BB_TX wrote:
Ford just introduced their new all electric Mustang with up to 459 HP, depending on model. And a range up to 300 miles on current battery technology. Obviously these manufacturers feel a battery breakthrough is imminent.
Yeah but you get 459hp or 300miles.
- Of course is it really 459hp... or HP equivilent (which really isn't a thing). Cars typically have way more peak HP than they need because low rpm available HP is much lower. Most cars never actually put out the rated peak HP in real life. With electric motors, you get more HP at low rpm, so less need for peak HP to get the same performance.
- 300mile range assumes you drive it like it's got a 4 banger and you are afraid to break it. Use that 459hp and you will be lucky to get 100mile range.
Really you are seeing lots about battery technology, not because a breakthrough is imminent but because it's the key stumbling block to making EVs a viable replacement for ICE.
