otrfun
Mar 31, 2017Explorer II
BobnKris wrote:
I'm considering purchasing the Yamaha 2000w combo generator set to use during an extended trip we have planned this year. I have a Coleman 15K AC on the trailer, and am curious if anybody uses the Yamaha combo to power a 15K AC and what limitations I should expect. I've had a Yamaha 2400 for several years, and it worked occasionally to power our 13.5K when at lower elevations, but need to have enough power to use the AC if needed for short(er) durations when not in an actual park with hookups. Any help is appreciated. I'm not opposed to the Honda setup, but I like that the Yamaha has the fuel shutoff whereas the Honda does not. From what I've read, the power output for either setup (Honda vs Yamaha) is similar, but insight or suggestions regarding one brand over another is also appreciated.
BobnKris wrote:The BTU rating of an RV a/c unit only gives you a very general idea about the inrush current necessary to start it. The LRA rating is a much more definitive indicator. FWIW, some 15k BTU RV a/c units actually have an LRA lower than some 13,5k BTU RV a/c units. In other words, depending on the LRA rating of a given RV a/c unit, a generator may be able to start a 15k BTU a/c unit and not start a 13.5k BTU a/c unit.
Sorry, to clarify: I mean the combo of 2 2000w Yamahas (4000w total). I know it works on paper, but I'm looking to see if anybody has practical experience using that gen setup with a 15K ac. Thanks for the help, and all replies are appreciated.
What's the LRA on your 15k RV a/c unit? The LRA is noted on the data sticker typically located underneath the upper, outside shroud. If it's 65 amps or higher, chances are two, paralleled 2000 Yamaha's may struggle, or even fail, to start it---especially under less than ideal conditions. The Yamaha's produce enough continuous current to run nearly any RV a/c unit, but may not produce enough inrush current to reliably start an RV a/c with an LRA of 65 - 70 amps under all conditions.
Even two, paralleled Honda EU2000i's would have a tough time with LRA's as high as 65 - 70 amps.
Does your 15k BTU RV a/c have an OEM start capacitor already installed? If not, then you may want to consider installing one. A start capacitor can potentially reduce the LRA approx. 10 percent.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
