BobnKris's avatar
BobnKris
Will the Yamaha 2000 combo generators power 15K AC
I'm considering purchasing the Yamaha 2000w combo generator set to use during an extended trip we have planned this year. I have a Coleman 15K AC on the trailer, and am curious if anybody uses the Yamaha combo to power a 15K AC and what limitations I should expect. I've had a Yamaha 2400 for several years, and it worked occasionally to power our 13.5K when at lower elevations, but need to have enough power to use the AC if needed for short(er) durations when not in an actual park with hookups. Any help is appreciated. I'm not opposed to the Honda setup, but I like that the Yamaha has the fuel shutoff whereas the Honda does not. From what I've read, the power output for either setup (Honda vs Yamaha) is similar, but insight or suggestions regarding one brand over another is also appreciated.
    I believe the Honda's fuel shuts off when the black knob is OFF.
    Not sure what 'combo' means, but 2kw will likely be a struggle.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
