Due to a leak in the window of the entry door, I removed the window today (standard two part plastic frame, sandwiching a single pane piece of glass) to clean things out and replace the sealant/gasket...
Thanks for the reply. I have no experience with butyl rubber tape, and do not understand your comment "Do not be overly generous....". I understand the concern about stripping the screw holes.
The stuff that I removed is like a two sided tape, about 1/4 wide but fairly thin (maybe a 1/16 of an inch thick, but hard to tell if that is the-now compressed thickness).
Do you mean do not apply multiple layers, or....? I presume this tape is available in different thicknesses?
Marv
