Gdetrailer
Jun 29, 2021Explorer III
No one can say for sure, all you can do is spend the money and see if it helps.
It may help or it may not, all depends on the noise in the little bit of signal you have to work with.. Amplifiers amplify not only the wanted signal but any noise and interference around you plus adds the noise generated by the amp into the output..
Garbage in + amp = amplified garbage out.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
