dougrainer
Dec 07, 2015Nomad
Your Carryout REQUIRES a constant 12 volt source to work even if you have already locked onto the Sat. Just like its big brother on motorhomes, without 12 volt power it can "drift" slightly. Keeping power to the dome keeps it locked on. If it starts to "drift", having that 12 volt power allows it to auto correct BEFORE you lose the signal. Doug
Verify power source is providing +12 VDC to the antenna.
• Try an additional power source. Verify the power supply
meets alternative power supply specifications at the bottom
of the page.
• Ensure that the power plug is fully seated and locked into
the power socket on the antenna.
of the page.
