CA_Traveler
Dec 07, 2015Explorer III
RoyB wrote:The DC power applied to the coax by the receiver is used for the LNB antenna and is 2 different voltages depending upon channel selection.
I guess most of us are being confused by the requirement for 12VDC that is present on the RG cable to power up the internal PRE-AMPLIFIER of the dish unit.
Not being familiar with any of this I am assuming you have an additional 12VDC being provided to the dish motor circuit to move the antenna pointing directions.
Roy Ken
The manual implies that the unit needs the additional 12V power to switch between satellites. So apparently the OP moved or is trying to access different channels and now needs to leave the unit plugged into 12V for the motor.
