dougrainer
Dec 08, 2015Nomad
chalet05 wrote:
Problem solved thanks to bgum. With good signal strength, I didn't think to move the dome - still not sure what was causing the interruption.
At any rate, everything is working correctly and THE 12 VOLT HAS BEEN DISCONNECTED!!
WHAT fixed it? You do not state exactly what fixed the problem. But, regardless, Winegard states that continued 12 volts will always keep it locked on. Just because you CAN disconnect the 12 volts does NOT mean it will work for everyone. Doug
