chindog
May 25, 2020Explorer
Sounds like you may have a switch or splitter between your outside satellite hookup and your VIP211K. You can try running a cable through a window directly from the receiver to the Pathway X2 to verify they are still working. If they do, you may need to run a separate cable line from your entertainment center to an outside bay to connect the Pathway X2. That's what I had to do with mine, and it wasn't too difficult once I figured out a path to run the cable.
