8ntw8tn
May 25, 2020Explorer
chindog wrote:
Sounds like you may have a switch or splitter between your outside satellite hookup and your VIP211K. You can try running a cable through a window directly from the receiver to the Pathway X2 to verify they are still working. If they do, you may need to run a separate cable line from your entertainment center to an outside bay to connect the Pathway X2. That's what I had to do with mine, and it wasn't too difficult once I figured out a path to run the cable.
I'm pretty sure this is going to be my corrective procedure. If I knew where the switch or splitter was located it would certainly help and I'll try to find it, but this is more likely to be the most effective route. Thanks, all.
