- ADAD437Exploreri run about a quart of af thru the pump then pour the rest down the p traps.
- MuddydogsExplorerI have blown the lines on 30 trailers for 10+ years and never had a problem with just running the pump dry for a minute or less.
- wtmtnhikerExplorer
Tim Nowicki wrote:
I just remove my pump and take it indoors. Less than five minutes. No worries!!
Tim
I thought about that but mine is really hard to get to. Decided to run a gallon of AF through the lines after I blew them out which kind of defeated the purpose of why I wanted to blow them out as opposed to using AF. - Tim_NowickiExplorerI just remove my pump and take it indoors. Less than five minutes. No worries!!
Tim - John_JoeyExplorer
2oldman wrote:
Does blow do the pump?-Nov 2012
That was a good thread/link.
I see 3 years later people are now pushing just air on the forum. I guess some will have issues and we'll then go back to the common knowledge we had back in 2012.
I buy a cheap toilet hose at the hardware store. Fits on my pump intake perfect, and the other end draws out of an AF bottle. Keep it with the rig, simple. - Empty_Nest__SooExplorer
DrewE wrote:
What I do is run it dry for fifteen or thirty seconds and then finish blowing the lines out.
Yes. Running it dry will pump the water out and air through it. Enough air so that nothing will freeze.
Wayne - RoyFExplorerI use anti-freeze; AF is passes through the water pump on it way to the hot and cold lines, so the pump must be full of AF after winterizing.
- DrewEExplorer IIIWhat I do is run it dry for fifteen or thirty seconds and then finish blowing the lines out.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
