Dave_H_M
Oct 01, 2014Explorer II
You can forget it if you want and it will probably be ok. However me I wouldn't dare.
If you got the system pressurized and stick a screwdriver in there with enough force to dislodge the one way valve that water and stuff will initially shoot out of there like a cannon. If you want to do the valve release thing, go inside or use the outdoor shower to depressurize, release the valve in the inlet and then stand clear while holding the ball valve in and have someone turn on the pump.
I got tired of all that and made an adapter to go from the outdoor shower to the city water inlet. I simply turn on the outdoor shower and let it put the pink stuff in the city water tube.
BTW I know a guy that broke his city water inlet valve first time out of the chute. :S
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
