RoyB
Oct 17, 2014Explorer III
I have two converters on my 12VDC Power Distribution system installed in the 2009 time frame..
I have the original WFCO WF8945 Converter still functional in the bottom compartment of the WF8900 series Power Distribution system.
I also added a PD9260C Stand-alone Smart Mode CONVERTER which is much closer to the battery switch later on..
This is my wiring diagram showing both converters in use. I only use the WF8945 Converter as a back up unit and the PD0260C Converter as primary. I simply just flip the correct 120VAC Circuit breaker to turn 'ON' the converter I want to use.
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
