Grey_MountainExplorerJan 20, 2014Wire for 50A 220V Service - 110' runI have on hand about 30' of #2 aluminum wire and about 100' of #6 aluminum wire. The run from the breaker to the outlet will be about 120'. Can I run about 30' or so of #2, then continue with #6 to ...Show More
MM49ExplorerJan 20, 2014You might want check again. All of the answers are wrong.MM49Wire Size Calculator
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
Related ContentAdding power outlets in slide with no wiringAccidentally plugged into 220vFleetwood Angler wiring2005 SixPac D850 WiringBad tail light wiring
