Housted
Jan 21, 2014Explorer III
If you have an existing 30 amp 4 wire circuit use it. Put a 50 amp outlet for the 5er to plug in to and go on. You will NOT have 50 amps but you probably don't need that much in a storage situation anyway.
When we went to a 50 amp rig, that is what I did and it works just fine. Use a twin 30 amp breaker so both hots are protected properly. All you loose is some capacity!!
Housted
Housted
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
