Ozlander
Jan 21, 2014Explorer
Housted wrote:
If you have an existing 30 amp 4 wire circuit use it. Put a 50 amp outlet for the 5er to plug in to and go on. You will NOT have 50 amps but you probably don't need that much in a storage situation anyway.
When we went to a 50 amp rig, that is what I did and it works just fine. Use a twin 30 amp breaker so both hots are protected properly. All you loose is some capacity!!
Housted
That is what I would do. Just beware that if you have both air conditioners running and turn on a table saw or some other high load, you may trip the breakers. But, you can learn to live with it.
After all, if you're in a park with only 30 amp service, you're running everything on just one 30 amp service and you can deal with that....
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
