BurbMan
Jan 30, 2014Explorer III
Grey Mountain wrote:
OK, here's what I did:
Enclosed the exposed cable in conduit. Using a 60amp breaker off the pole, used all four wires in the cable (previously, one wire was not used). Installed another breaker box in the barn, two hots, one neutral and one ground. Using two 30amp breakers to feed the 4-pin RV outlet. Separate 10amp circuit for the lights in the barn.
I'll have my son-in-law check everything to make sure I don't curl my hair.
GM
What did your son in law say? Was hoping that a real sparky would say yea/nay on this, I am not an expert on NEC.
BTW, code does not allow purple martin houses in residential applications, it must be a wren house.
