BFL13's avatar
BFL13
Explorer II
Oct 04, 2013
Wire Gauge Required Question
For some reason I just can't understand the various wire gauge tables, and I have tried to, so I am hoping somebody will take pity and do all the work! :)
One table that I can follow says that for a 12v system, and a 16 amp solar controller, you need (to be within 1/2 volt drop) for a solar array connection to controller of 30 ft (round trip)-- #12, or for 40ft-- #10
I take that to mean either 15 ft away or 20 ft away.
This same source says to double the voltages for 24v in their example for calculating voltage drop, so does that mean with 24v, 1.0v drop is ok on that line? NOTE this is in a manual for a PWM controller. ISTR with MPPT you want a tighter control on voltage drop.
Anyway I am lost here. My question is, "What wire gauge of stranded copper would you need for 16 amps with a 24v system 30ft away (60 ft round trip) with an MPPT controller?"
EDIT--also, please with a 24v panel and MPPT, do you use the 12v figures for the controller battery, but the 24v figures for the controller array wires?
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,259 PostsLatest Activity: May 31, 2025
