CA_Traveler
Aug 10, 2019Explorer III
The chart that may be misleading and has little to offer. Why would the 10 ga be incorrect when the plug type may be the limiting factor? Why is their a difference between 2 vs 3 prong 16 gauge? Insulation type maybe? The cord cover color has no significance in the US, don't know about Canada. Are the amp ratings even correct?
I'd prefer a chart that shows distance vs voltage drop. I suppose amp draw can be helpful but I suspect that most assume that a 20 amp plug cord can be used - well for a 20A draw, with little consideration for 15A vs 20A rated plugs.
Actually I'd use a wire gauge calculator.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
