McKenziek's avatar
McKenziek
Wire Size & fuses for solar install
I have 4 140 Watt 12v panels connected in parallel on the roof. I took the guy at Solar Blvd's advice and bought #10 AWG wire for the run to the controller. Controller is a Mornigstar TS-45 PWM. It is about 35' away from the panels. Is this wire size big enough? Should I use the same size wire to the battery bank? And lastly what size and type fuse should I use between the load & batteries to the controller or should I use a re-settable breaker?
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
