time2roll
Jan 16, 2014Nomad
On edit: 2/0 is probably overkill. But if you have it on hand you may as well use it. #4 is plenty in most cases and is about max you can fit in the converter terminals. Maybe #2 if the converter is a 90amp IOTA or 100 amp WFCO or Powermax.
For maximum charging performance pull 120v wire to move the converter closer to the battery.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
