mena661
Jan 16, 2014Explorer
Thanks Larry for clearing that up. Went back and reread the OP. For a standard converter (like 55 amps), 2/0 would be a bit overkill for a 12 foot run. I'd go with #1 or even #2. If you're getting the 2/0 cheap or just don't mind spending on that size then 2/0 is just fine. You'll probably have to trim the end to fit in the converters lugs.
