westend
Apr 27, 2014Explorer
I rewired my Starcraft brakes, replacing the series connected wiring with a star configuration. I led both wires from each brake assembly forward in conduit to a terminal strip. The terminal strip is mounted in a box on the tongue. Since all my wiring is inside on the terminal strips, I can easily check if power is present or even measure current (if I desired).
I see a lot of posts where 10 AWG is the wire of choice but I have miles of 14 AWG on hand so that's what I used. Brakes are functioning well.
