RCMAN46
Apr 27, 2014Explorer
I have a Prodigy P3 controller. My brakes will lock up at about 7 volts on the Prodigy. That is about 60% of the available voltage. Increasing the wire size probably will do nothing as the controller will lock the brakes with the wire I have. Sending more current to the brakes will not accomplish anything.
The answer to your question, what voltage does it take to lock your brakes? If you are unable to lock brakes make sure they are in good condition no grease contamination and adjusted properly. If that is OK then a larger wire may give you more braking effort.
