suprz's avatar
suprz
Wire size?
Just making sure, low power LED strip less than 5ft, and the power wire is less than 3ft long. Can I use 20 gauge wire for the 12 volt power and ground? I don't believe the LEDs will draw more than an amp IF even that much
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Short answer: YES
    long answer It might be "overkill"
    But to be sure.. measure the voltage at both ends of the wire. I'd not worry about 1 volt loss or less.
  • suprz wrote:
    time2roll wrote:
    s/b fine. Consider a 5 amp fuse on the branch circuit.
    On the power IN, or the power out?
    At the point that you connect the #20 wire to the positive battery supply.
  • 2oldman wrote:
    I can't find a single ampacity chart that rates a 20awg wire. What is that, speaker wire? Anyway, it'll be ok, but don't put anything else on it.
    CHART
    20 AWG will work fine. My under cabinet lights in S&B is 8'6" and running on a 2 amp ps and #20 wire.
  • I can't find a single ampacity chart that rates a 20awg wire. What is that, speaker wire? Anyway, it'll be ok, but don't put anything else on it.
  • ppine's avatar
    ppine
    Explorer III
    20 gauge is awfully small for multiple lights.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
