kioticoachman
Jul 18, 2018Explorer
Johno02 wrote:
I checked about a new system me time ago, and was told that whatever was installed , there were adapters to allow the new system to use the old cables and plugs. Hope that helps you some. Most systems are wired to be on with the ignition, so that is not a problem. Whenever you are driving, it is on. No need to turn it off. Most larger RV supply stores will have whatever you need, or you can order online.
Thanks for taking the time to reply. I thought about a wireless unit, however from the information you provided, I think it best to replace the RVS camera with a newer model that the unit was originally wired and set up for the RVS. Thanks again! That helps!
