brulaz's avatar
brulaz
Wiring a 24V to 12V converter
Went crazy and decided to upgrade to a 24V system (and 2000W inverter).
Ordered a Victron Orion 24/12-40 converter for the 12V stuff (except emergency brake switch). It's rated 40A continuous output with 55A peak and is non-isolated. The converter will be located about 5' from the batteries.
Issue 1:
Just now noticed the Victron uses *two* 6.3mm Faston tabs for each of +24V, +12V and the common neg. And the manual says you should run two parallel cables for all three in/outputs when over 25A output is expected. So that sounds like I want two 10awg lines each with a big yellow AMP Faston female connector for every in/output.
But as I've already got lots of 6 awg cable available and in place, am thinking of just splicing/soldering very short sections 10 awg, with the Fastons on one end, into a single 6 awg cable for each of the three in/outputs?
Issue 2:
The 24V and 12V systems on the Victron have a common neg (are not isolated). Does that neg get wired to:
the 24V battery neg,
the chassis ground attached to battery neg,
a chassis ground nearer the converter?
Any suggestions or comments appreciated.
Having RV issues? Connect with others who have been in your shoes.24,302 PostsLatest Activity: Aug 17, 2025
