carmencina
Jun 02, 2023Explorer
Thanks for your contribution guys and please forgive my inexperience regarding image posting, will do that next time.
It's 220v.
@CA Traveler: Thanks a lot, your answer is super helpful!
The chassis/starter battery is lead acid, the house battery is Lithium, so I read the safe only way to charge the second from the first is to use a DC-DC charger instead of relays so that it can keep a steady 14.6v charge.
You've hit a painful spot! I am building this van in the countryside with limited tools and shops, everthing must be ordered online and it takes days to arrive, so I asked the solan panel company to wire the panels for me to save time. I asked for 10 AWG cables but later I thought I had made a mistake because I only calculated half the wire lenght so, despite myself, I thought I had to rewire the "long sides" with 6 AWG cables. But from your reply I understand my first calculation (10 AWG) was probably correct, right?
Here are the panel specs of each panel (translated from Chinese, no instruction manuals, only a minimal label on the back):
Peak power: 300W
Open circuit voltage: 22.5V
Short circuit current: 16. 6A
Working voltage: 18V
Working current: 15.5A
Total length of the cables is 3+3=6m (20ft). As they are in a series, the max current going through them is 16.6A?
From the MPPT to the battery there will be 40.8A and max 1ft distance, so I chose 6 AWG. From the inverter (1000w) to the battery I expect 100-120A max so 2 AWG should be enough but I wanted to cover for unexpected peaks up to 2000w if the CB fails so I chose 2/0 AWG. Useless?
My bad, I meant to connect the ground to the black cable in the diagram.
Thanks again!
Is China shore voltage 220 Volts or 120 Volts?
It's 220v.
What is the reason for the DC-DC charger?
Your solar has both 10 and 6 ga wires, should be the same.
Peak power: 300W
Wires should be as short as possible
the red AC wire grounded
Thanks again!
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
