jrnymn7
Jan 09, 2015Explorer
Yes, make it so.
Note: If you're adding two new batts in with two older ones, keep the two older ones together as a 12v string, and add the two new batts as another 12v string, and then parallel them into a single bank.
Try to get their resting (open circuit) voltages as close as possible before wiring them together. And be sure to use heavy cabling; at least 4ga, but 2ga is even better. And try to find heavy duty tinned copper terminal rings.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
