kydaleExplorerMay 05, 2017Wiring inverterI want to install an PSW inverter with transfer switch as part of the inverter to power a residential refrigerator. I want it to switch off and on automatically. Inverter 120v output writes to the ref...Show More
time2rollNomadMay 07, 2017If the inverter has a built in transfer switch it will send power out on the romex direct to the fridge, nothing else.If you are plugged in, the power will go to the inverter and just pass straight through and again go direct to the fridge.The transfer switch is a mechanical switch that will separate the two sources.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
Related ContentInverter Bad?Inverter installwiring in inverterInverter wire size?Inverter on Generator wiring?
