In laws just bought a 1995 coachman catalina 338fl the gfi in bathroom does not work and the wall out lets on that side does not work either and there is to lights in the slide for dinner and coach ar...
Lights should be 12 volts DC. What does the GFCI receptacle do when you press the test button? If it pops out when the test button is pushed what happens when you then push the reset. If the test button is out and the reset will not set the GFCI, then it has no power. Reset circuit breakers by turning them all off applying light pressure toward off, then turn on main then each of the branch breakers one at a time. Does anything work on 120 volts such as the AC unit or microwave?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
