joe6789
Oct 10, 2019Explorer
enblethen wrote:
The neutrals would be from different power sources and must be kept separate.
The inverter neutral should (shall) be grounded where the shore power connection cannot be grounded in the rig and must be complete separate.
Enblethen, thanks for the info. Another feature of the Multiplus is that it opens its ground relay when receiving shore power, thus relying on the shore power ground. And then when shore power is disconnected, the Multiplus uses its own ground to the rig. So it smartly switches between grounding in the rig and grounding through the shore power connection.
Does that change the thinking at all?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
