CA_Traveler
Oct 10, 2019Explorer III
OP,
What you may be missing is that charger/inverters switch both the neutral and hot line and the output neutral and ground are bonded when inverting (only).
You will also need to split the neutral in the panel and run a 2nd neutral from the inverter output to the panel. And there may be other considerations.
As Mayer said it can be done but not recommended.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
