theoldwizard1
Oct 10, 2019Explorer II
Neutral is neutral. Ground is ground. All neutral should meet at the neutral bus bar inside the breaker panel. All grounds should meet at the ground bus bar inside the breaker panel.
KISS ! Simple and elegant !
joe6789 wrote:
The Multiplus can supplement short power with inverted battery power simultaneously. However, I don't expect to need that feature. I will usually either be connected to 50A shore power OR boondocking off batteries (with occasional generator use).
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
