joe6789
Oct 10, 2019Explorer
time2roll wrote:joe6789 wrote:Not sure what you mean by "alongside".
Time2roll, just to be clear, that means L2 would go direct to the panel with no neutral and no ground going alongside it. Correct? This is exactly how I initially planned to wire it, but I've seen some suggestions that L2 needs its own neutral and grounds rather than relying on the neutral and ground coming out of the inverter.
L1,N,G take a detour though the inverter and continue to the main panel. I would assume as L1, N, G emerge from the inverter and continue to the main panel they would be physically alongside L2.
Sorry, by "alongside" I meant N and G literally taking the same path as L2 (not through inverter). Yes, eventually the N and G return from the inverter and would indeed be physically next to L2. However I've seen advice saying there should be separate N and G that do not detour through the inverter.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
