3_tons
Oct 11, 2019Explorer III
enblethen wrote:
neutrals are not always common. It depends on the overall system as whether they can or cannot be tied together.
The block diagram shows separating the neutrals via the relay.
In Appendix B of the manual, it appears to me that the relay is for the purposes of bonding neutral to ground when outside power is not present...This is typical of many inverter-chargers and provided due to NEC code.
https://www.victronenergy.com/upload/documents/Manual-MultiPlus-Compact-2000-120V-EN.pdf
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
