enblethen
Oct 17, 2019Nomad
The drawing does not identify where each of the devices are located.
1)Disconnect the wires(all) that are for the circuit going to the items you want to power off inverter.
2)Connect the inverter to the 120 volt panel in the same location. Phase conductor to the breaker, ground and neutral to their individual buss bars.
3)At the converter, connect the wires from the circuit breaker to the inverter input.
4) Connect the branch circuit to the inverter. This can be done using a cord body plugged into the inverter output.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
