CA_Traveler
Oct 17, 2019Explorer III
enblethen wrote:OK but my impression is that the OP plans to connect to half of the RV panel with no other wiring changes at the panel. So he'll manage all of the existing loads like the second A/C on the inverter circuit.
The drawing does not identify where each of the devices are located.
1)Disconnect the wires(all) that are for the circuit going to the items you want to power off inverter.
2)Connect the inverter to the 120 volt panel in the same location. Phase conductor to the breaker, ground and neutral to their individual buss bars.
3)At the converter, connect the wires from the circuit breaker to the inverter input.
4) Connect the branch circuit to the inverter. This can be done using a cord body plugged into the inverter output.
While I would rewire the panel and RV apparently the OP doesn't want to use this approach.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
