joe6789
Oct 21, 2019Explorer
Follow up question:
There are two 50A circuit breakers that each hot leg currently passes through in the breaker panel. But with the upcoming MultiPlus inverter installation, one of the hot legs will route through the inverter before entering that 50A breaker.
Since that breaker comes after the inverter, I believe it is no longer sufficient. I believe I'll need to install one additional 50A breaker or fuse before the inverter.
Is that correct?
Is that correct?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
