enblethen
Oct 21, 2019Nomad
The 50 amp double pole breaker in the rig is a main breaker with the handles tied to gether.
If you are set on modifying the existing panel as stated, you would need to remove the existing double pole breaker and install one 50 amp single pole breakers to feed the primary buss. Then install a breaker in the second buss and back-feed into the buss from the inverter.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
