joe6789
Oct 21, 2019Explorer
enblethen wrote:
The 50 amp double pole breaker in the rig is a main breaker with the handles tied to gether.
If you are set on modifying the existing panel as stated, you would need to remove the existing double pole breaker and install one 50 amp single pole breakers to feed the primary buss. Then install a breaker in the second buss and back-feed into the buss from the inverter.
Why is it necessary to have two single pole breakers rather than using the existing double pole breaker? Seems like I should be able to run both lines into the existing double pole breaker, one of which routes through the inverter first.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
