time2roll
Nov 03, 2019Nomad
dropping 1 or 2 volts is too much for no load. Dropping to 1 or 2 volts is a defective battery or open connection. Where exactly are you measuring the voltage? Inverter should pull no more than 2 amps at idle that might show 0.1 volt drop in battery voltage.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
